Saltar al contenido principal
Disassembling Asus Eee PC 1000HE Lower Assembly
Qué necesitas
  1. Disassembling Asus Eee PC 1000HE Lower Assembly, Lower Assembly: paso 1, imagen 1 de 1
    • Turn off the power and remove the battery before working on your Eee PC
    • Start by removing the keyboard
    • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
    • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
    • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
    • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
  2. Disassembling Asus Eee PC 1000HE Lower Assembly: paso 2, imagen 1 de 2 Disassembling Asus Eee PC 1000HE Lower Assembly: paso 2, imagen 2 de 2
    • 7 screws hold the front plate to the motherboard, as well as the ones on the rear of the PC.
    • Before taking off the case, you need to disconnect the touchpad and hotkeys cables.
Conclusión
Una persona más ha completado esta guía.
adammw
Miembro Desde 01/21/11
111 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,162
