Make sure the laptop is powered off before starting. Remove the battery.
  • Make sure the laptop is powered off before starting. Remove the battery.
  • Use a plastic opening tool to pry out the narrow plastic lid.
    • You may use a flat-head screwdriver for this task, but will most likely scratch the keyboard and the plastic lid itself.
    • Exercise caution when re-assembling: carefully and gently snap the lid back on. The plastic lid may easily break since it is made of a thin and soft plastic material.
    • Before replacing the lid, you may want to power on the laptop and test that the keyboard is working properly.
Agregar Comentario
Remove the following screws securing the top of the keyboard:
  • Remove the following screws securing the top of the keyboard:
    • Four 3mm Phillips screws.
Agregar Comentario
  • In this next step, the keyboard is still attached to the logic board via a flat cable. Be careful not to tear the cable or damage the connector by removing the keyboard too quickly or too abruptly or pulling it too far away from the laptop.
  • Lift the keyboard away from the laptop, starting from the top end which is nearest to the screen.
Agregar Comentario
  • Use the tip or the flat end of a nylon spudger to unlock the connector securing the flat cable of the keyboard to the logic board.
  • Pull the flat cable out not up.
    • When re-assembling, insert and hold the flat cable in place with one hand; use the other hand to lock the connecter using the tip or flat end of a nylon spudger. If you release the flat cable before locking the connector, it will most probably slip out.
Agregar Comentario
Conclusión
26 personas más completaron esta guía.
Rany
Miembro Desde 15/08/12
32,969 Reputación
2 Guías creadas
Equipo
iCenter SARL Miembro de iCenter SARL
Business
1 Miembro
2 Guías creadas
I had to take my laptop apart to fix broken hinges which had been put in at factory was to stiff and it had cut the power connector inside. I replaced the power connector woth a new one and made a few little repairs, put everything back together but the keyboard did not work. After watching this video I redid the ribbon connection under the keyboard more carefully and and it works great. Thanks for posting this video. It was very helpful. This was my first time to work on a Laptop. Feeling great about my first laptop home repair.
kse143 - Contestar
Cool. Thanks loads
btoboh - Contestar
What did you do about the hinges ? This one on my machine is to tight and broke ?
sundaymoney - Contestar
TIPS
There is a gold Torx male part located at F6.
You will have a hard time prying up there.
That's the worst issue.
There are tabs you will break off at F1, INS & HOME.
I broke two being careful.
You could hot glue in place if necessary.
DON'T BREAK the tabs on the ends of the lid.
Those keep it in place.
I thought the ribbon might be a stupid design like GE digital phones, not so.
Pop the connector using your fingernail.
The ribbon slides into place.
great design ...
Test & good to go ...
FingA - Contestar
This was helpful thank you now my keyboard works
Feras Alassal - Contestar
Thank you for your tips:) much appreciate
Shivaram - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 55
Últimos 7 Días: 387
Últimos 30 Días: 1,709
Todo El Tiempo: 56,975
