Introducción
Disassembly
1. Flip toaster over.
2. Locate four phillips screws on the bottom of the toaster.
3. Loosen and remove.
4. Sides will pop out once screws are removed.
  1. 1. Flip toaster over.
    • 1. Flip toaster over.
  2. 2. Locate four phillips screws on the bottom of the toaster.
    • 2. Locate four phillips screws on the bottom of the toaster.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. 3. Loosen and remove using a Phillips head screwdriver
    • 3. Loosen and remove using a Phillips head screwdriver
  5. 4. Sides will pop out once screws are removed.
    • 4. Sides will pop out once screws are removed.
Conclusión
Carlos
Miembro Desde 23/07/13
101 Reputación
1 Guía escrita
Equipo
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - Contestar
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 16
Todo El Tiempo: 691
