1. First: Eye Camera
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Remove 4 screws.
    • Remove 4 screws.
  3. Remove cover to get to the PCB underneath
    • Remove cover to get to the PCB underneath
  4. Remove two screws on the PCB.
    • Remove two screws on the PCB.
  5. Remove PCB from the base plastic piece.
    • Remove PCB from the base plastic piece.
  6. Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Completed assembly of the eye camera.
    • Completed assembly of the eye camera.
  9. Back of pupil camera is glued on. Remove with flat-head.
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Remove the black frame on the front of the pupil camera.
    • Remove the black frame on the front of the pupil camera.
  11. Once frame is taken off the front, two screws need to be removed. Once frame is taken off the front, two screws need to be removed.
    • Once frame is taken off the front, two screws need to be removed.
  12. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  13. One screw removed from the back.
    • One screw removed from the back.
  14. Front housing comes off once the screws are removed from the frame.
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  15. Pull off bottom stand until it breaks off.
    • Pull off bottom stand until it breaks off.
  16. Remove rubber/plastic piece from the bottom Remove rubber/plastic piece from the bottom
    • Remove rubber/plastic piece from the bottom
  17. Remove four screws from under the plastic tape (removed from last step).
    • Remove four screws from under the plastic tape (removed from last step).
  18. Bottom pops off Bottom pops off
    • Bottom pops off
  19. Separate the metal frame from the plastic assembly. Avoid the cables
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  20. Take out PCB from the plastic housing.
    • Take out PCB from the plastic housing.
  21. Remove the rest of the black plastic housing. Remove the rest of the black plastic housing. Remove the rest of the black plastic housing.
    • Remove the rest of the black plastic housing.
  22. Black plastic housing removed
    • Black plastic housing removed
  23. Continue removing the black plastic housing surrounding the inner PCB. Continue removing the black plastic housing surrounding the inner PCB. Continue removing the black plastic housing surrounding the inner PCB.
    • Continue removing the black plastic housing surrounding the inner PCB.
  24. PCB removed from the black plastic housing. PCB removed from the black plastic housing.
    • PCB removed from the black plastic housing.
  25. Autofocus assembly.
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  26. Unscrew the lens
    • Unscrew the lens
  27. Take out the IR filter by using a scalpel for pulling out the lens tape. Take out the IR filter by using a scalpel for pulling out the lens tape.
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  28. Comparison photos of completed autofocus assembly vs in-progress autofocus assembly Comparison photos of completed autofocus assembly vs in-progress autofocus assembly Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  29. IR LEDs replaced by SMD LED Soldering required here (at bottom of LED to remove).
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  30. SMD LED info: Thick black line is near the positive side of the LED
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  31. Insert PCB into 3d-printed frame. Insert PCB into 3d-printed frame. Insert PCB into 3d-printed frame.
    • Insert PCB into 3d-printed frame.
  32. Completed assembly. Sugru used for nose/head rest
    • Completed assembly.
    • Sugru used for nose/head rest
Conclusión
Una persona más ha completado esta guía.
Silas
Miembro Desde 25/11/13
291 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 568
