Saltar al contenido principal
Dirt Devil Scorpion Quick Flip Power Cord Replacement
Qué necesitas
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: paso 2, imagen 1 de 2 Dirt Devil Scorpion Quick Flip Power Cord Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: paso 3, imagen 1 de 1
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: paso 4, imagen 1 de 1
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 302
