Saltar al contenido principal
Dirt Devil Scorpion Quick Flip Filter Adapter Replacement
  1. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: paso 1, imagen 1 de 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: paso 1, imagen 2 de 2
    • First, press the button on the handle of the vacuum to separate the two halves.
    • The button triggers a release mechanism, detaching the front half from the back of the vacuum.
  2. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: paso 2, imagen 1 de 1
    • Once the front half has been separated from the back half, locate the filter adapter.
    • The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
    • Grasp the filter and adapter. Pull them out together.
  3. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: paso 3, imagen 1 de 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: paso 3, imagen 2 de 2
    • Rotate the filter counterclockwise to remove it from the filter adapter.
    • Once the filter adapter has been removed from the filter, replace it.
Conclusión
Joseph Warner
Miembro Desde 11/11/17
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Wilson Fall 2017 Miembro de IUPUI, Team S1-G1, Wilson Fall 2017
IUPUI-WILSON-F17S1G1
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 503
