Saltar al contenido principal
Dirt Devil Gator Motor Replacement
Qué necesitas
  1. Dirt Devil Gator Motor Replacement, Motor: paso 1, imagen 1 de 1
    • Press the button found at the top of the vacuum to separate the suction cup and the motor halves.
  2. Dirt Devil Gator Motor Replacement: paso 2, imagen 1 de 3 Dirt Devil Gator Motor Replacement: paso 2, imagen 2 de 3 Dirt Devil Gator Motor Replacement: paso 2, imagen 3 de 3
    • Pull apart the two halves to obtain the back half and set the front half aside
  3. Dirt Devil Gator Motor Replacement: paso 3, imagen 1 de 3 Dirt Devil Gator Motor Replacement: paso 3, imagen 2 de 3 Dirt Devil Gator Motor Replacement: paso 3, imagen 3 de 3
    • Unscrew each of the 13 mm screws with the micro screwdriver.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
  4. Dirt Devil Gator Motor Replacement: paso 4, imagen 1 de 3 Dirt Devil Gator Motor Replacement: paso 4, imagen 2 de 3 Dirt Devil Gator Motor Replacement: paso 4, imagen 3 de 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Motor Replacement: paso 5, imagen 1 de 1
    • Remove the motor from the Dirt Devil Gator exterior by pulling slightly on the white socket.
    • Replace it with a new motor by fitting the motor back into its socket.
    • Be cautious when handling the batteries and wires.
    • Keep the grey on-off switch in the "off" position to ensure a quick reassembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 418
