Saltar al contenido principal
Direct-Drive Cleaner Head Brush Bar Replacement
Qué necesitas
  1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: paso 1, imagen 1 de 2 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: paso 1, imagen 2 de 2
    • First, make sure the device is unplugged and detached from the wand
    • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
    • Padlocks
  2. Direct-Drive Cleaner Head Brush Bar Replacement: paso 2, imagen 1 de 1
    • Slide the brush bar away from the cleaner head
Conclusión
6 personas más completaron esta guía.
Equipo
UW Tacoma, Team S1-G5, Rose Fall 2017 Miembro de UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
Miembros de 4
16 Guías creadas
2Guía Comentarios
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - Contestar
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 89
Todo El Tiempo: 37,153
