Saltar al contenido principal
Digital2 Platinum Pad 9 Volume Buttons Replacement
Qué necesitas
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: paso 1, imagen 1 de 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 2, imagen 1 de 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 2, imagen 2 de 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 3, imagen 1 de 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 3, imagen 2 de 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: paso 4, imagen 1 de 1
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 5, imagen 1 de 1
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 6, imagen 1 de 1
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 7, imagen 1 de 1
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 8, imagen 1 de 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
Conclusión
David DeMeritt
Miembro Desde 03/08/16
637 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 101
