Saltar al contenido principal
Digital2 Platinum Pad 9 External Cover Replacement
Qué necesitas
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: paso 1, imagen 1 de 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: paso 2, imagen 1 de 2 Digital2 Platinum Pad 9 External Cover Replacement: paso 2, imagen 2 de 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: paso 3, imagen 1 de 2 Digital2 Platinum Pad 9 External Cover Replacement: paso 3, imagen 2 de 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Conclusión
David DeMeritt
Miembro Desde 03/08/16
637 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 291
