Saltar al contenido principal
Digital2 D2-912 Speaker Replacement
Qué necesitas
  1. Digital2 D2-912 Speaker Replacement, External Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Speaker Replacement: paso 2, imagen 1 de 2 Digital2 D2-912 Speaker Replacement: paso 2, imagen 2 de 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Digital2 D2-912 Speaker Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-1, Harley Fall 2015 Miembro de IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 161
