Saltar al contenido principal
Digital2 D2-912 Motherboard Replacement
Qué necesitas
  1. Digital2 D2-912 Motherboard Replacement, External Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Motherboard Replacement: paso 2, imagen 1 de 2 Digital2 D2-912 Motherboard Replacement: paso 2, imagen 2 de 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Remove the wires shown in the image, using a soldering iron and solder sucker.
    • By removing the wires, you are detaching the battery and speaker from the motherboard.
  4. Digital2 D2-912 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
  5. Digital2 D2-912 Motherboard Replacement: paso 5, imagen 1 de 2 Digital2 D2-912 Motherboard Replacement: paso 5, imagen 2 de 2
    • Detach the capacitive touch controller from the motherboard.
    • Carefully pry the narrow black connector upward to release the ribbon.
    • Remove the ribbon from the connector.
  6. Digital2 D2-912 Motherboard Replacement: paso 6, imagen 1 de 1
    • Locate the camera found in the image.
    • Carefully pry the black connector upward to release ribbon.
    • Remove the black tape to release the camera from the motherboard.
    • Remove and replace the motherboard.
Conclusión
2 personas más completaron esta guía.
Jason Wignot
Miembro Desde 09/16/15
322 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-1, Harley Fall 2015 Miembro de IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 380
