Introducción
The following guide will show you how to replace the charging port for the Digitac Jazz Ultratab C725.
Qué necesitas
Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
Remove all four screws with the Phillips #00 screwdriver.
Flip your device so that the long side without the buttons is facing you.
Insert the plastic opening tool between the silver back plate and the screen. From the corner of the device on either side, pry the seam of the device about 1 inch.
With the plastic opening tool, pry the screen apart from the back plate.
Keep prying the screen apart from the back plate until they are separated.
With the plastic opening tool, if necessary, pry apart the remaining seams of the device.
Una persona más ha completado esta guía.
