Qué necesitas
Paso 1 Digiland 10.1'' DL1016 Remove Backing
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Paso 4 Digiland 10.1'' DL1016 Remove Battery
Aviso: el paso 4 proviene de una guía que está marcada como "En progreso".
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
Un comentario
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
