Saltar al contenido principal
DigiTech RP70 Motherboard Replacement
Qué necesitas
  1. DigiTech RP70 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 DigiTech RP70 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Motherboard Replacement: paso 2, imagen 1 de 2 DigiTech RP70 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Motherboard Replacement: paso 4, imagen 1 de 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Conclusión
Una persona más ha completado esta guía.
3 comentarios
My digitech rp 80 not work. How to get new motherboard
Thadevus - Contestar
My digitecj rp 80 not working. No display no sound how to get new motherboard
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 889
