Saltar al contenido principal
DigiTech RP70 DC Power Connector Replacement
Qué necesitas
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: paso 1, imagen 1 de 2 DigiTech RP70 DC Power Connector Replacement, Motherboard: paso 1, imagen 2 de 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: paso 2, imagen 1 de 2 DigiTech RP70 DC Power Connector Replacement: paso 2, imagen 2 de 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: paso 3, imagen 1 de 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: paso 4, imagen 1 de 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: paso 5, imagen 1 de 1
    • Desolder the back of the motherboard where the power connector is located.
Conclusión
Un comentario
Later? I cant see to other
ISAAC SALAZAR - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 313
