Saltar al contenido principal
Introducción
If the AC power connector is broken this guide will teach you how to remove the broken component for replacement.
Partes
No se especificaron partes.
  1. Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks. Remove the four 8mm Phillips #0 screws located on the back panel.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. Remove the back panel to expose the motherboard. Remove the back panel to expose the motherboard.
    • Remove the back panel to expose the motherboard.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  5. Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  6. Desolder the back of the motherboard where the power connector is located.
    • Desolder the back of the motherboard where the power connector is located.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 75
