Saltar al contenido principal
DigiLand DL8006 Speaker Replacement
Qué necesitas
  1. DigiLand DL8006 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: paso 2, imagen 1 de 2 DigiLand DL8006 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: paso 3, imagen 1 de 2 DigiLand DL8006 Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: paso 4, imagen 1 de 3 DigiLand DL8006 Speaker Replacement: paso 4, imagen 2 de 3 DigiLand DL8006 Speaker Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: paso 6, imagen 1 de 2 DigiLand DL8006 Speaker Replacement: paso 6, imagen 2 de 2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 142
