Saltar al contenido principal
DigiLand DL700D Motherboard Replacement
Qué necesitas
  1. DigiLand DL700D Motherboard Replacement, Battery: paso 1, imagen 1 de 3 DigiLand DL700D Motherboard Replacement, Battery: paso 1, imagen 2 de 3 DigiLand DL700D Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the device's back cover using the plastic opening tool.
  2. DigiLand DL700D Motherboard Replacement: paso 2, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 2, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. DigiLand DL700D Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the wifi antenna from the bottom of the battery.
  4. DigiLand DL700D Motherboard Replacement: paso 4, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 4, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 4, imagen 3 de 3
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  5. DigiLand DL700D Motherboard Replacement: paso 5, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 5, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
  6. DigiLand DL700D Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Desolder the WiFi antenna from the motherboard.
  7. DigiLand DL700D Motherboard Replacement: paso 7, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 7, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove 3 ribbon cables attached to the motherboard by lifting the plastic retainer, then pulling the cable out.
  8. DigiLand DL700D Motherboard Replacement: paso 8, imagen 1 de 2 DigiLand DL700D Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove adhesive attaching the motherboard to the casing.
  9. DigiLand DL700D Motherboard Replacement: paso 9, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 9, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the three 2.5 mm Phillips #1 screws holding the motherboard to the case.
  10. DigiLand DL700D Motherboard Replacement: paso 10, imagen 1 de 3 DigiLand DL700D Motherboard Replacement: paso 10, imagen 2 de 3 DigiLand DL700D Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove motherboard from the case and replace.
Conclusión
To reassemble, follow these instructions in reverse order.
Justin Edwards
Miembro Desde 03/29/18
241 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G4, Harley Spring 2018 Miembro de IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 264
