Saltar al contenido principal
Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement
Qué necesitas
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement, Unplug: paso 1, imagen 1 de 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 2, imagen 1 de 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 2, imagen 2 de 2
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 3, imagen 1 de 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 3, imagen 2 de 2
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 4, imagen 1 de 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 4, imagen 2 de 2
    • Remove the switch from his housing in order to have access to it.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 5, imagen 1 de 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 5, imagen 2 de 2
    • Unscrew the two screws.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 6, imagen 1 de 3 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 6, imagen 2 de 3 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 6, imagen 3 de 3
    • Replace the component.
    • Tighten the screws well after putting the cables back on.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 7, imagen 1 de 1
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  8. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 8, imagen 1 de 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: paso 8, imagen 2 de 2
    • Replace the external flange, the protective cover and the side handle.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
37 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 215
