Saltar al contenido principal
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
Qué necesitas
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: paso 1, imagen 1 de 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 2, imagen 1 de 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 2, imagen 2 de 2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 3, imagen 1 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 3, imagen 2 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 3, imagen 3 de 3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 4, imagen 1 de 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 4, imagen 2 de 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 9, imagen 1 de 1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 11, imagen 1 de 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 11, imagen 2 de 2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 13, imagen 1 de 1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 14, imagen 1 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 14, imagen 2 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 14, imagen 3 de 3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 17, imagen 1 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 17, imagen 2 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 17, imagen 3 de 3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 18, imagen 1 de 1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 20, imagen 1 de 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 20, imagen 2 de 2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 21, imagen 1 de 1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 22, imagen 1 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 22, imagen 2 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 22, imagen 3 de 3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 24, imagen 1 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 24, imagen 2 de 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 24, imagen 3 de 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 25, imagen 1 de 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 25, imagen 2 de 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: paso 26, imagen 1 de 1
    • Finally, reposition the vacuum bag.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 145
