Saltar al contenido principal
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
Qué necesitas
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: paso 1, imagen 1 de 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 2, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 2, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 2, imagen 3 de 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 3, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 3, imagen 2 de 2
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 4, imagen 1 de 1
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 5, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 5, imagen 2 de 2
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 6, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 6, imagen 2 de 2
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 8, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 8, imagen 2 de 2
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 10, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 10, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 10, imagen 3 de 3
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 13, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 13, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 13, imagen 3 de 3
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 14, imagen 1 de 1
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 15, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 15, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: paso 15, imagen 3 de 3
    • Replace the tip, strip and handle.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 143
