Saltar al contenido principal
Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable
Qué necesitas
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable, Unplug: paso 1, imagen 1 de 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 2, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 2, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 2, imagen 3 de 3
    • Remove the handle, unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 3, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 3, imagen 2 de 2
    • Pry the tape off.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 4, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 4, imagen 2 de 2
    • Unscrew the screws to open the hull.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 5, imagen 1 de 1
    • Remove the two screws that block the cable.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 6, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 6, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 6, imagen 3 de 3
    • Release the brown cable.
    • Unscrew the screw on the domino.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 7, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 7, imagen 2 de 2
    • Then release the blue cable.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 8, imagen 1 de 1
    • Remove the old cable and replace it with the new one.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 9, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 9, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 9, imagen 3 de 3
    • Put the cables back in their place and screw the domino and switch. Then put each room back into their home.
    • The brown cable must be positioned below.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 10, imagen 1 de 1
    • Close and screw the device.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 11, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: paso 11, imagen 2 de 2
    • Replace the band and handle.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 96
