Saltar al contenido principal
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
Qué necesitas
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: paso 1, imagen 1 de 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 2, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 2, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 2, imagen 3 de 3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 3, imagen 1 de 2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 3, imagen 2 de 2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 4, imagen 1 de 1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 5, imagen 1 de 1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 6, imagen 1 de 1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 8, imagen 1 de 1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 9, imagen 1 de 1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 11, imagen 1 de 1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 12, imagen 1 de 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 12, imagen 2 de 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: paso 12, imagen 3 de 3
    • Replace the tip, strip and handle.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 301
