Saltar al contenido principal
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
Qué necesitas
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: paso 1, imagen 1 de 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 2, imagen 1 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 2, imagen 2 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 2, imagen 3 de 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 3, imagen 1 de 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 3, imagen 2 de 2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 4, imagen 1 de 1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 5, imagen 1 de 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 5, imagen 2 de 2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 6, imagen 1 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 6, imagen 2 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 6, imagen 3 de 3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 7, imagen 1 de 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 7, imagen 2 de 2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 10, imagen 1 de 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 10, imagen 2 de 2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 11, imagen 1 de 1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 12, imagen 1 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 12, imagen 2 de 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: paso 12, imagen 3 de 3
    • Replace the tip, band and handle.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 111
