Saltar al contenido principal
Dexter 750W Wired Jigsaw Power Cable Replacement
Qué necesitas
  1. Dexter 750W Wired Jigsaw Power Cable Replacement, Unplug: paso 1, imagen 1 de 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 2, imagen 1 de 1
    • Remove the vacuum adaptor on the back of the device.
  3. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 3, imagen 1 de 2 Dexter 750W Wired Jigsaw Power Cable Replacement: paso 3, imagen 2 de 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 4, imagen 1 de 1
    • Remove the two screws to unlock the cable.
  5. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 5, imagen 1 de 1
    • Remove the black screw, in order to remove the wheel.
    • Thanks to a screwdriver, leverage to be able to recover the wheel.
  6. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 7, imagen 1 de 2 Dexter 750W Wired Jigsaw Power Cable Replacement: paso 7, imagen 2 de 2
    • Turn the switch over.
    • Unscrew the 2 screws to remove the blue and brown cables.
  7. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 8, imagen 1 de 1
    • Reconnect the new cable.
    • The brown thread must be at the top and the blue thread must be at the bottom.
  8. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 9, imagen 1 de 2 Dexter 750W Wired Jigsaw Power Cable Replacement: paso 9, imagen 2 de 2
    • Reposition each room in its housing.
    • Then screw each screw.
  9. Dexter 750W Wired Jigsaw Power Cable Replacement: paso 10, imagen 1 de 1
    • Close and screw the device.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,698 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
Miembros de 38
241 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 335
