Saltar al contenido principal
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
Qué necesitas
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: paso 1, imagen 1 de 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 2, imagen 1 de 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 2, imagen 2 de 2
    • Remove the dust case and the seal on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 3, imagen 1 de 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 3, imagen 2 de 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 3, imagen 3 de 3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 4, imagen 1 de 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 4, imagen 2 de 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 5, imagen 1 de 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 5, imagen 2 de 2
    • Unscrew the two screws from the domino to pull out the brown and blue cables.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 6, imagen 1 de 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 6, imagen 2 de 2
    • Reconnect the new cable to the domino.
    • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 7, imagen 1 de 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 7, imagen 2 de 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 7, imagen 3 de 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 8, imagen 1 de 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 8, imagen 2 de 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: paso 9, imagen 1 de 1
    • Finally, reposition the vacuum bag.
Linea de Meta
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Céline Chemineau
Miembro Desde 01/29/20
16,581 Reputación
95 Guías creadas
Equipo
Leroy Merlin Miembro de Leroy Merlin
Community
36 Miembros
239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 137
