Unscrew the first screw from the pad.
Then unscrew the remaining four screws and pull up to remove it.
Finally, remove the screws located on the shell of the device.
Replace the hull of the sander, taking care to properly position the stabilisers in their housings.
Replace the pad by positioning it perfectly in the tips.
Screw the four screws
Then the last screw. Finally, put the joint back in its place.
Un agradecimiento especial a estos traductores:
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Incrustar esta guía
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Vista previa
