Saltar al contenido principal
Dewalt DCF885 Switch Assembly Replacement
Qué necesitas
  1. Dewalt DCF885 Switch Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Switch Assembly Replacement: paso 2, imagen 1 de 1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Switch Assembly Replacement, Motor Assembly: paso 3, imagen 1 de 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Switch Assembly Replacement: paso 4, imagen 1 de 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Switch Assembly Replacement: paso 5, imagen 1 de 1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Switch Assembly Replacement: paso 6, imagen 1 de 1
    • Pull the motor away from the brush assembly.
  7. Dewalt DCF885 Switch Assembly Replacement, Brush Assembly: paso 7, imagen 1 de 1
    • Lift the brush assembly out of the drill case.
  8. Dewalt DCF885 Switch Assembly Replacement: paso 8, imagen 1 de 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. Dewalt DCF885 Switch Assembly Replacement: paso 9, imagen 1 de 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. Dewalt DCF885 Switch Assembly Replacement: paso 10, imagen 1 de 1
    • The brush assembly is now removed from the drill body.
  11. Dewalt DCF885 Switch Assembly Replacement, Switch Assembly: paso 11, imagen 1 de 1
    • Pull the switch assembly up and out of the drill case.
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 45
Todo El Tiempo: 2,151
