Saltar al contenido principal
Dewalt DCD778 Forward/Reverse Switch Replacement
Qué necesitas
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: paso 1, imagen 1 de 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: paso 2, imagen 1 de 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: paso 3, imagen 1 de 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: paso 4, imagen 1 de 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: paso 5, imagen 1 de 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: paso 6, imagen 1 de 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: paso 7, imagen 1 de 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Conclusión
Brittany
Miembro Desde 03/09/19
693 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 11
Ultimos 30 días: 45
Todo El Tiempo: 1,749
