Saltar al contenido principal
Disassembling Dell OptiPlex FX170 Case
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Disassembling Dell OptiPlex FX170 Case, Case: paso 1, imagen 1 de 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Disassembling Dell OptiPlex FX170 Case: paso 2, imagen 1 de 2 Disassembling Dell OptiPlex FX170 Case: paso 2, imagen 2 de 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Disassembling Dell OptiPlex FX170 Case: paso 3, imagen 1 de 3 Disassembling Dell OptiPlex FX170 Case: paso 3, imagen 2 de 3 Disassembling Dell OptiPlex FX170 Case: paso 3, imagen 3 de 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Disassembling Dell OptiPlex FX170 Case: paso 4, imagen 1 de 2 Disassembling Dell OptiPlex FX170 Case: paso 4, imagen 2 de 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 58
