Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Desktop PC RAM Replacement
Qué necesitas
  1. Desktop PC RAM Replacement, Left Panel: paso 1, imagen 1 de 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: paso 2, imagen 1 de 2 Desktop PC RAM Replacement: paso 2, imagen 2 de 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: paso 4, imagen 1 de 1
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
Conclusión
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 personas más completaron esta guía.
David Lennon
Miembro Desde 04/14/15
10,144 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 4-5, Maness Spring 2015 Miembro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
Miembros de 4
45 Guías creadas
4Guía Comentarios
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Contestar
how to determine the speed
benzy aceware - Contestar
how can i differentiate between types of rams
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 19
Ultimos 30 días: 131
Todo El Tiempo: 8,329
