Saltar al contenido principal
Desktop PC Motherboard Replacement
Qué necesitas
  1. Desktop PC Motherboard Replacement, Left Panel: paso 1, imagen 1 de 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Motherboard Replacement: paso 2, imagen 1 de 2 Desktop PC Motherboard Replacement: paso 2, imagen 2 de 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Motherboard Replacement, Right Panel: paso 3, imagen 1 de 1
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
  4. Desktop PC Motherboard Replacement: paso 4, imagen 1 de 2 Desktop PC Motherboard Replacement: paso 4, imagen 2 de 2
  5. Desktop PC Motherboard Replacement, Graphics Card: paso 5, imagen 1 de 1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  6. Desktop PC Motherboard Replacement: paso 6, imagen 1 de 2 Desktop PC Motherboard Replacement: paso 6, imagen 2 de 2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
  7. Desktop PC Motherboard Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
  8. Desktop PC Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
  9. Desktop PC Motherboard Replacement: paso 9, imagen 1 de 1
    • Slide the hard drive out from the metal casing.
  10. Desktop PC Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the cables from the back of the hard drive.
  11. Desktop PC Motherboard Replacement, Motherboard: paso 11, imagen 1 de 2 Desktop PC Motherboard Replacement, Motherboard: paso 11, imagen 2 de 2
    • Begin to disconnect all cables from the motherboard. Many of the cables will have clips that need to be undone before you can remove them from the motherboard.
  12. Desktop PC Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove nine Phillips #2 head 5mm screws from the motherboard. Be sure to have your computer on its side, so that once the screws are out nothing falls and gets damaged.
  13. Desktop PC Motherboard Replacement: paso 13, imagen 1 de 1
    • Double check and make sure all wires and screws have been removed, then carefully remove the motherboard from the computer case.
Conclusión
108 personas más completaron esta guía.
David Lennon
Miembro Desde 04/14/15
9,944 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 4-5, Maness Spring 2015 Miembro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Miembros
45 Guías creadas
5 comentarios
If you aim to replace just the motherboard, I don’t think removing the hard drive from the case should be neccessary. The point of removing SATA cable from the motherboard still stands.
Ingmārs Zaicevs - Contestar
Generally a good article for a beginner. Very thorough. I personally do not remove the hard drives or cpu fans as it makes it both faster and easier to hold. Disconnect all the cables and graphics card then unscrew the motherboard screws and you are good to go!
Scott Sinclair - Contestar
such great info thanks for sharing with us.great blog
jade kelly - Contestar
hey my pc turn on but it doesn't show on screen.
Thapelo - Contestar
Hi, first thing I would check is video output default settings, so if you have the monitor connected to a dedicated/discreet graphics card try connecting the video cable to the mobo integrated one or viceversa. Otherwise, the fix could be as simple as replacing the BIOS battery (if the motherboard you are using as replacement is an old one) but could also be a hardware failure/compatibility issue, or a missing power cable (do you hear any beep during power-on self-test?), knowing the PC specs would help identify the problem.
Simone -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 69
Ultimos 30 días: 309
Todo El Tiempo: 29,468
