Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
A computer graphics card allows a computer to plug into a monitor and be displayed. Graphics cards are vital components for computers. Also, replacing a graphics card can help your computer run more quickly and smoothly.
Partes
No se especificaron partes.
  1. Unplug the computer from the power supply before any maintenance or disassembly.
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove. If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer. A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
Conclusión
69 personas más completaron esta guía.
David Lennon
Miembro Desde 14/04/15
9,134 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 4-5, Maness Spring 2015 Miembro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Miembros
26 Guías creadas
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - Contestar
I have a all in one pc so this is not relevant
Robert Campanelli - Contestar
any diffrerences in slots?
benzy aceware - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 122
Todo El Tiempo: 10,704
