Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Desktop PC GPU Replacement
Qué necesitas
    1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: paso 1, imagen 1 de 1
      • Minimize exposure to items that can charge up and produce static electricity.
      • Use an anti-static wrist band.
      Pregunta a FixBot
      Agregar Comentario
    2. Desktop PC GPU Replacement, Turn Off Computer: paso 2, imagen 1 de 1
      • Power off PC via Windows.
      • Switch off Power Supply
      Pregunta a FixBot
      Agregar Comentario
    3. Desktop PC GPU Replacement, Unscrew Case Side Panel: paso 3, imagen 1 de 2 Desktop PC GPU Replacement, Unscrew Case Side Panel: paso 3, imagen 2 de 2
      • Put screws where you wont lose them
      Pregunta a FixBot
      Agregar Comentario
    4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: paso 4, imagen 1 de 1
      • Be gentle to not pull with to much force when removing power cables.
      Pregunta a FixBot
      Agregar Comentario
    5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: paso 5, imagen 1 de 1
      • Try not to touch other components.
      Pregunta a FixBot
      Agregar Comentario
      • Gently pull the card out of the slot.
      Pregunta a FixBot
      Agregar Comentario
    6. Desktop PC GPU Replacement, Insert New GPU: paso 7, imagen 1 de 1
      • Verify that the notch in the connector matches the motherboard before sliding in.
      • Carefully slide in GPU until you hear a click on the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    7. Desktop PC GPU Replacement, Connect Power Cables: paso 8, imagen 1 de 1
      • Insert wisdom here.
      Pregunta a FixBot
      Agregar Comentario
    8. Desktop PC GPU Replacement, Re-Attach Side Panel: paso 9, imagen 1 de 1
      • Use same screws from step 2.
      Pregunta a FixBot
      Agregar Comentario
      • Flip power supply switch back to on.
      • Plug in PC and turn on.
      • If PC does not post go back through the steps to see if you missed something.
      Pregunta a FixBot
      Agregar Comentario
      • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
      Pregunta a FixBot
      Agregar Comentario
      • Enjoy your new GPU.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
3 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 113
Todo El Tiempo: 2,432
