Saltar al contenido principal
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
Qué necesitas
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: paso 1, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: paso 1, imagen 2 de 2
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 2, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 2, imagen 2 de 2
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 3, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 3, imagen 2 de 2
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 4, imagen 1 de 1
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 5, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 5, imagen 2 de 2
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 6, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 6, imagen 2 de 2
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 7, imagen 1 de 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 7, imagen 2 de 2
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 8, imagen 1 de 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 8, imagen 2 de 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: paso 8, imagen 3 de 3
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
Linea de Meta
Una persona más ha completado esta guía.
Theodore Tan
Miembro Desde 02/24/15
137 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 23-4, Green Winter 2015 Miembro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 504
