Saltar al contenido principal
Dell XPS M1530 Wireless Card Replacement
Qué necesitas
  1. Dell XPS M1530 Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Wireless Card Replacement: paso 3, imagen 1 de 2 Dell XPS M1530 Wireless Card Replacement: paso 3, imagen 2 de 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
  5. Dell XPS M1530 Wireless Card Replacement: paso 5, imagen 1 de 2 Dell XPS M1530 Wireless Card Replacement: paso 5, imagen 2 de 2
    • Lift the panel up from the indented area.
    • This indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
  7. Dell XPS M1530 Wireless Card Replacement: paso 7, imagen 1 de 1
    • Lift the card out at an angle and carefully remove it.
  8. Dell XPS M1530 Wireless Card Replacement: paso 8, imagen 1 de 2 Dell XPS M1530 Wireless Card Replacement: paso 8, imagen 2 de 2
    • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
    • Note the order of colors for the antenna cables indicated on the card.
Conclusión
Una persona más ha completado esta guía.
Jase Sasaki
Miembro Desde 01/22/15
721 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 18-4, Maness Winter 2015 Miembro de Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
Miembros de 4
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,798
