Saltar al contenido principal
Dell XPS M1530 RAM Replacement
Qué necesitas
  1. Dell XPS M1530 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 RAM Replacement: paso 2, imagen 1 de 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 RAM Replacement: paso 3, imagen 1 de 2 Dell XPS M1530 RAM Replacement: paso 3, imagen 2 de 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
    • Four 3.9mm Phillips #1 screws
    • One 5.8mm Phillips #1 screw
  5. Dell XPS M1530 RAM Replacement: paso 5, imagen 1 de 2 Dell XPS M1530 RAM Replacement: paso 5, imagen 2 de 2
    • Using the highlighted indent, pull up and out to remove the back panel.
    • The indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 RAM Replacement: paso 6, imagen 1 de 2 Dell XPS M1530 RAM Replacement: paso 6, imagen 2 de 2
    • Push out on the first set of metal tabs to release and remove the top RAM chip.
  7. Dell XPS M1530 RAM Replacement: paso 7, imagen 1 de 3 Dell XPS M1530 RAM Replacement: paso 7, imagen 2 de 3 Dell XPS M1530 RAM Replacement: paso 7, imagen 3 de 3
    • Push out on the second set of metal tabs to release and remove the lower RAM chip.
Conclusión
3 personas más completaron esta guía.
Jase Sasaki
Miembro Desde 01/22/15
721 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 18-4, Maness Winter 2015 Miembro de Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 882
