Saltar al contenido principal
Dell XPS M1530 Hard Drive Replacement
Qué necesitas
  1. Dell XPS M1530 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: paso 3, imagen 1 de 2 Dell XPS M1530 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell XPS M1530 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: paso 6, imagen 1 de 2 Dell XPS M1530 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Conclusión
Una persona más ha completado esta guía.
Tyler Scholz
Miembro Desde 01/22/15
479 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-4, Maness Winter 2015 Miembro de Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 2,044
