Saltar al contenido principal
Dell XPS M140 Screen Replacement
Qué necesitas
  1. Dell XPS M140 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • The first step is to turn over the laptop
  2. Dell XPS M140 Screen Replacement: paso 2, imagen 1 de 1
    • Locate the slide lock for the battery.
  3. Dell XPS M140 Screen Replacement: paso 3, imagen 1 de 2 Dell XPS M140 Screen Replacement: paso 3, imagen 2 de 2
    • Slide the lock and pull out the battery.
  4. Dell XPS M140 Screen Replacement, Screen: paso 4, imagen 1 de 3 Dell XPS M140 Screen Replacement, Screen: paso 4, imagen 2 de 3 Dell XPS M140 Screen Replacement, Screen: paso 4, imagen 3 de 3
    • On the plastic casing around the screen, there should be gray rubber circles lining the perimeter of the casing.
    • Remove these by peeling them off.
    • This will expose the screws underneath.
  5. Dell XPS M140 Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew the screws on the casing that you just exposed.
  6. Dell XPS M140 Screen Replacement: paso 6, imagen 1 de 3 Dell XPS M140 Screen Replacement: paso 6, imagen 2 de 3 Dell XPS M140 Screen Replacement: paso 6, imagen 3 de 3
    • Remove the casing.
    • This step requires care; the casing is secured with plastic clips that need to be popped off.
    • Run your hand, or a tool, around the perimeter, the casing should come off.
  7. Dell XPS M140 Screen Replacement: paso 7, imagen 1 de 3 Dell XPS M140 Screen Replacement: paso 7, imagen 2 de 3 Dell XPS M140 Screen Replacement: paso 7, imagen 3 de 3
    • Once the casing is removed, more screws should be exposed.
    • Remove every screw.
  8. Dell XPS M140 Screen Replacement: paso 8, imagen 1 de 3 Dell XPS M140 Screen Replacement: paso 8, imagen 2 de 3 Dell XPS M140 Screen Replacement: paso 8, imagen 3 de 3
    • Once all of the screws are removed, the screen should be loose.
    • Gently pick it up and place it face down onto the keyboard.
  9. Dell XPS M140 Screen Replacement: paso 9, imagen 1 de 3 Dell XPS M140 Screen Replacement: paso 9, imagen 2 de 3 Dell XPS M140 Screen Replacement: paso 9, imagen 3 de 3
    • There should be two connections.
    • One with a blue looking handle, and one with clips.
    • To remove the connection with the clips, squeeze the two clips together and pull the ribbon cable.
    • To remove the connection with the blue handle, gently pull on the blue handle, it should come right off.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 303
