Saltar al contenido principal
Dell XPS M1330 Keyboard Replacement
Qué necesitas
  1. Dell XPS M1330 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Keyboard Replacement: paso 2, imagen 1 de 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Keyboard Replacement: paso 3, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 3, imagen 2 de 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Keyboard Replacement, Hard Drive: paso 4, imagen 1 de 1
  5. Dell XPS M1330 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the four 3.0mm Phillips #1 screws securing the hard drive casing.
  6. Dell XPS M1330 Keyboard Replacement: paso 6, imagen 1 de 3 Dell XPS M1330 Keyboard Replacement: paso 6, imagen 2 de 3 Dell XPS M1330 Keyboard Replacement: paso 6, imagen 3 de 3
    • Slide the hard drive away from the computer, slowly and carefully.
  7. Dell XPS M1330 Keyboard Replacement, Fan: paso 7, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement, Fan: paso 7, imagen 2 de 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  8. Dell XPS M1330 Keyboard Replacement: paso 8, imagen 1 de 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  9. Dell XPS M1330 Keyboard Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  10. Dell XPS M1330 Keyboard Replacement: paso 10, imagen 1 de 1
    • Gently remove the fan and its attachments from the bay.
  11. Dell XPS M1330 Keyboard Replacement, CPU: paso 11, imagen 1 de 1
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  12. Dell XPS M1330 Keyboard Replacement: paso 12, imagen 1 de 1
    • Using the iFixit opening tool, prop up the CPU.
  13. Dell XPS M1330 Keyboard Replacement: paso 13, imagen 1 de 1
    • Carefully lift the CPU away from its housing.
  14. Dell XPS M1330 Keyboard Replacement, Keyboard: paso 14, imagen 1 de 1
    • Unscrew the 5.0mm Phillips #1 screw from the wireless door cover.
    • Pull straight up on the wireless door.
  15. Dell XPS M1330 Keyboard Replacement: paso 15, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 15, imagen 2 de 2
    • Unscrew the 3.0mm Phillips #1 screw from the wireless card.
  16. Dell XPS M1330 Keyboard Replacement: paso 16, imagen 1 de 3 Dell XPS M1330 Keyboard Replacement: paso 16, imagen 2 de 3 Dell XPS M1330 Keyboard Replacement: paso 16, imagen 3 de 3
    • Slide the card to the left and up to remove it.
  17. Dell XPS M1330 Keyboard Replacement: paso 17, imagen 1 de 3 Dell XPS M1330 Keyboard Replacement: paso 17, imagen 2 de 3 Dell XPS M1330 Keyboard Replacement: paso 17, imagen 3 de 3
    • Separate the two clips on both sides of the memory sticks.
    • The memory stick will lift up.
    • Gently pull the memory stick up and out of its holder.
    • Repeat these same steps for the second memory stick below.
  18. Dell XPS M1330 Keyboard Replacement: paso 18, imagen 1 de 1
    • Remove the two 2.5mm Phillips #1 screws in the battery housing port.
  19. Dell XPS M1330 Keyboard Replacement: paso 19, imagen 1 de 1
    • Flip the laptop back over so the cover is on top.
  20. Dell XPS M1330 Keyboard Replacement: paso 20, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 20, imagen 2 de 2
    • Carefully open the screen, so it is facing toward yourself.
    • Flatten out the screen as much as possible.
  21. Dell XPS M1330 Keyboard Replacement: paso 21, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 21, imagen 2 de 2
    • Carefully lift the computer, so you can get a good grip by the hinges.
    • Carefully lift and remove the central control media button cover from the base.
    • This piece snaps out of its constraints. Be slow and controlled, so you don't break a snap. There is also a cable attached underneath.
  22. Dell XPS M1330 Keyboard Replacement: paso 22, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove the two 3.0mm screws at the top of the keyboard.
  23. Dell XPS M1330 Keyboard Replacement: paso 23, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 23, imagen 2 de 2
    • When removing this piece lift slowly as there is a cord underneath that connects to the keyboard.
    • Carefully lift the keyboard up and toward the front screen.
  24. Dell XPS M1330 Keyboard Replacement: paso 24, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 24, imagen 2 de 2
    • Lift the keyboard latch toward yourself.
  25. Dell XPS M1330 Keyboard Replacement: paso 25, imagen 1 de 2 Dell XPS M1330 Keyboard Replacement: paso 25, imagen 2 de 2
    • Gently pull the keyboard cable away from your body.
    • Detach the keyboard cable.
Conclusión
Kai Kapossy
Miembro Desde 03/24/19
676 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 574
