Saltar al contenido principal
Dell XPS 9720 Battery Replacement
Qué necesitas
  1. Dell XPS 9720 Battery Replacement, Remove back cover: paso 1, imagen 1 de 1
    • Remove 8 T5 screws. Use an opening tool to pop open the plastic tabs that hold the aluminum and plastic halves of the shell together. Begin by inserting the tool at any point, then sliding it around the perimeter of the device to release all of the tabs. There are no tabs along the hinge side of the device.
  2. Dell XPS 9720 Battery Replacement, Unplug the battery: paso 2, imagen 1 de 2 Dell XPS 9720 Battery Replacement, Unplug the battery: paso 2, imagen 2 de 2
    • Place a finger through the plastic loop attached to the battery plug, and pull firmly away from the motherboard.
  3. Dell XPS 9720 Battery Replacement, Remove battery screws: paso 3, imagen 1 de 2 Dell XPS 9720 Battery Replacement, Remove battery screws: paso 3, imagen 2 de 2
    • Unscrew the 7 PH1 screws retaining the battery.
    • The battery can now be lifted from the chassis.
    • Reverse the steps to install the new battery.
Conclusión
Una persona más ha completado esta guía.
Sebastien Bolle
Miembro Desde 09/12/15
350 Reputación
3 Guías creadas
Un comentario
Is there anything to do on the software side to the battery replacement? Or is it plug and play?
Steven Savoie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 82
Todo El Tiempo: 1,320
