Saltar al contenido principal
Dell XPS 7590 SSD Replacement
Qué necesitas
  1. Dell XPS 7590 SSD Replacement, Flip laptop around: paso 1, imagen 1 de 1
    • Flip your device the other way around
    • Don't be confused that this device is black, its a skin
  2. Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: paso 2, imagen 1 de 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: paso 2, imagen 2 de 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: paso 2, imagen 3 de 3
    • Grab your T5 Torx and identify the 10 torx screws
    • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
    • Careful there are more screws, do not try to open yet!
  3. Dell XPS 7590 SSD Replacement, Remove Flap Screws: paso 3, imagen 1 de 1
    • Open the flap on the back of the laptop
    • There are two screws that need to be removed, please use a Philips 0 screwdriver
  4. Dell XPS 7590 SSD Replacement, Remove Backplate: paso 4, imagen 1 de 1
    • The backplate might not be easy to open
    • You can use a soft prytool to open the laptop easier
    • Don't insert the tool too deep or you might break the mainboard
    • Now, you should be able to remove the backplate
  5. Dell XPS 7590 SSD Replacement, Unplug Battery: paso 5, imagen 1 de 3 Dell XPS 7590 SSD Replacement, Unplug Battery: paso 5, imagen 2 de 3 Dell XPS 7590 SSD Replacement, Unplug Battery: paso 5, imagen 3 de 3
    • Locate the battery connection to the mainboard
    • Unplug the battery before doing anything else
    • You can use a pry tool to make this easier
  6. Dell XPS 7590 SSD Replacement, Locate and remove SDD: paso 6, imagen 1 de 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: paso 6, imagen 2 de 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: paso 6, imagen 3 de 3
    • Locate the SDD on the mainboard
    • Use a Philips 0 to remove the screw of the SDD
    • Slide the SSD out of its socket.
    • Try not to lift the SSD any more than necessary
    • During reassembly, make sure the slot in the SSD lines up with the slot in its socket. Do not touch the gold-colored contacts with your fingers.
    • Reconnect the battery and reassemble
Conclusión
4 personas más completaron esta guía.
Max Lembke
Miembro Desde 09/14/19
951 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 57
Todo El Tiempo: 3,276
