Saltar al contenido principal
Dell XPS 18 Touch Control Board Replacement
Qué necesitas
  1. Dell XPS 18 Touch Control Board Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Touch Control Board Replacement: paso 2, imagen 1 de 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Touch Control Board Replacement: paso 3, imagen 1 de 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Touch Control Board Replacement, Internal Cover: paso 4, imagen 1 de 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Touch Control Board Replacement: paso 5, imagen 1 de 2 Dell XPS 18 Touch Control Board Replacement: paso 5, imagen 2 de 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Touch Control Board Replacement: paso 6, imagen 1 de 2 Dell XPS 18 Touch Control Board Replacement: paso 6, imagen 2 de 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: paso 7, imagen 1 de 2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: paso 7, imagen 2 de 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Touch Control Board Replacement: paso 8, imagen 1 de 2 Dell XPS 18 Touch Control Board Replacement: paso 8, imagen 2 de 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Touch Control Board Replacement: paso 9, imagen 1 de 2 Dell XPS 18 Touch Control Board Replacement: paso 9, imagen 2 de 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
Conclusión
4 personas más completaron esta guía.
Austin Weir
Miembro Desde 01/31/15
1,287 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-29, Amido Winter 2015 Miembro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Miembros
16 Guías creadas
2 comentarios
It worked perfectly. Thank you.
Kenneth Macdonald - Contestar
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,912
