Saltar al contenido principal
Dell XPS 18 Left and Right Speakers Replacement
Qué necesitas
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: paso 2, imagen 1 de 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: paso 3, imagen 1 de 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: paso 4, imagen 1 de 2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: paso 4, imagen 2 de 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: paso 5, imagen 1 de 1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: paso 6, imagen 1 de 1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: paso 7, imagen 1 de 1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Conclusión
Una persona más ha completado esta guía.
Austin Weir
Miembro Desde 01/31/15
1,287 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-29, Amido Winter 2015 Miembro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,265
