Saltar al contenido principal
Dell XPS 18 Battery Replacement
Qué necesitas
  1. Dell XPS 18 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: paso 2, imagen 1 de 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: paso 3, imagen 1 de 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: paso 4, imagen 1 de 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Battery Replacement: paso 5, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: paso 6, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 6, imagen 2 de 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: paso 7, imagen 1 de 2 Dell XPS 18 Battery Replacement, Touch Control Board: paso 7, imagen 2 de 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: paso 8, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 8, imagen 2 de 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: paso 9, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 9, imagen 2 de 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: paso 10, imagen 1 de 1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Battery Replacement: paso 11, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 11, imagen 2 de 2
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: paso 12, imagen 1 de 1
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
  13. Dell XPS 18 Battery Replacement: paso 13, imagen 1 de 1
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
  14. Dell XPS 18 Battery Replacement: paso 14, imagen 1 de 2 Dell XPS 18 Battery Replacement: paso 14, imagen 2 de 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: paso 15, imagen 1 de 1
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: paso 16, imagen 1 de 1
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: paso 17, imagen 1 de 1
    • Remove the battery.
Conclusión
13 personas más completaron esta guía.
Austin Weir
Miembro Desde 01/31/15
1,287 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-29, Amido Winter 2015 Miembro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Miembros
16 Guías creadas
9 comentarios
needs the help to repair the Dell XPS18
anrew waleta - Contestar
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - Contestar
It all worked good. Thanks.
Kenneth Macdonald - Contestar
Excellent!
What is the battery type and where to buy, thanks
Mohammad - Contestar
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 60
Todo El Tiempo: 15,949
