Saltar al contenido principal
  1. Flip over the laptop with the bottom battery compartment facing up.
    • Flip over the laptop with the bottom battery compartment facing up.
  2. Slide the tab below the battery leftwards and hold. Slide the tab below the battery leftwards and hold.
    • Slide the tab below the battery leftwards and hold.
  3. While holding the tab, lift the battery out of its compartment. Release the tab after removing the battery.
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Loosen the module cover screw with a Phillips screwdriver.
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover, do not force it out.
  5. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards. Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Use a Phillips screwdriver and unscrew four 4mm Phillips screws fastening the first hard drive. Use a Phillips screwdriver and unscrew four 4mm Phillips screws fastening the first hard drive.
    • Use a Phillips screwdriver and unscrew four 4mm Phillips screws fastening the first hard drive.
  7. Slide the hard drive towards the hole where the back panel assembly screw was located with your hands to disconnect and lift to remove it. Slide the hard drive towards the hole where the back panel assembly screw was located with your hands to disconnect and lift to remove it. Slide the hard drive towards the hole where the back panel assembly screw was located with your hands to disconnect and lift to remove it.
    • Slide the hard drive towards the hole where the back panel assembly screw was located with your hands to disconnect and lift to remove it.
  8. Use a Phillips screwdriver to unscrew four 4mm Phillips screws on the second hard drive.
    • Use a Phillips screwdriver to unscrew four 4mm Phillips screws on the second hard drive.
  9. Slide the hard drive towards the edge nearest you to disconnect it. Slide the hard drive towards the edge nearest you to disconnect it.
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Using the tab that says "this side up"  pull away from the laptop to remove the hard drive. Using the tab that says "this side up"  pull away from the laptop to remove the hard drive. Using the tab that says "this side up"  pull away from the laptop to remove the hard drive.
    • Using the tab that says "this side up" pull away from the laptop to remove the hard drive.
  11. Repeat this step  for each hard drive. Unscrew two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
    • Repeat this step for each hard drive.
    • Unscrew two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Remove the hard drive casing.
    • Remove the hard drive casing.
  13. Unscrew the screw holding the optical drive with a Phillips screwdriver.
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Using a plastic opening tool, pull out the optical drive. Using a plastic opening tool, pull out the optical drive. Using a plastic opening tool, pull out the optical drive.
    • Using a plastic opening tool, pull out the optical drive.
  15. Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Push and hold the tab inside the optical drive's opening with your index finger. Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces. Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Slide the spudger around the palm rest to release the clips. You may hear crackling noise, this is normal.
    • Slide the spudger around the palm rest to release the clips.
    • You may hear crackling noise, this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires. The mouse pad wires are still connected to the palm rest panel.
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Put the Spudger below the black tab of the wider cable and push up to release. Gently Pull out the cable. Gently Pull out the cable.
    • Put the Spudger below the black tab of the wider cable and push up to release.
    • Gently Pull out the cable.
  21. Insert the spudger below the black tab of the remaining cable and push up to release. Gently pull out the cable. Gently pull out the cable.
    • Insert the spudger below the black tab of the remaining cable and push up to release.
    • Gently pull out the cable.
  22. Remove the palm rest from the laptop.
    • Remove the palm rest from the laptop.
  23. Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop. DO NOT lift the keyboard all the way as wires are still connected. DO NOT lift the keyboard all the way as wires are still connected.
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way as wires are still connected.
  24. Gently insert the spudger below the edge of the black tab of the thinner cable and lift. Gently pull out the cable. Gently pull out the cable.
    • Gently insert the spudger below the edge of the black tab of the thinner cable and lift.
  25. Gently insert the spudger under the edge of the black tab of the cable marked UP. Gently pull out the cable. Gently pull out the cable.
    • Gently insert the spudger under the edge of the black tab of the cable marked UP.
  26. Remove the keyboard from the laptop.
    • Remove the keyboard from the laptop.
  27. Flip the laptop over so that the bottom faces upwards. Remove the two 16 mm screws with a Phillips screwdriver.
    • Flip the laptop over so that the bottom faces upwards.
    • Remove the two 16 mm screws with a Phillips screwdriver.
  28. Gently flip over the laptop and open the back cover assembly.
    • Gently flip over the laptop and open the back cover assembly.
  29. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach. Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
  30. Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw. Gently pull out the WLAN card. Gently pull out the WLAN card.
    • Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
    • Gently pull out the WLAN card.
  31. Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach
    • Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach
    • Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach
  32. Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver.  The card will lift itself after you do so Gently pull out the WWAN card Gently pull out the WWAN card
    • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself after you do so
    • Gently pull out the WWAN card
  33. Gently remove the wires for WLAN and WWAN cards from their housing. Gently remove the wires for WLAN and WWAN cards from their housing. Gently remove the wires for WLAN and WWAN cards from their housing.
    • Gently remove the wires for WLAN and WWAN cards from their housing.
  34. Unscrew four 8mm screws directly under the keyboard with a Phillips screwdriver.
    • Unscrew four 8mm screws directly under the keyboard with a Phillips screwdriver.
  35. Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver. DO NOT ATTEMPT TO REMOVE SCREW FROM WIRE it is permanently fixed onto the wire.
    • Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
    • DO NOT ATTEMPT TO REMOVE SCREW FROM WIRE it is permanently fixed onto the wire.
  36. Using the plastic opening tool, detach the connection from the cable to the board. Using the plastic opening tool, detach the connection from the cable to the board.
    • Using the plastic opening tool, detach the connection from the cable to the board.
  37. Gently remove the monitor cable from its holdings from the board.
    • Gently remove the monitor cable from its holdings from the board.
  38. Hold the plastic edge of the display firmly and lift to remove the display. Hold the plastic edge of the display firmly and lift to remove the display. Hold the plastic edge of the display firmly and lift to remove the display.
    • Hold the plastic edge of the display firmly and lift to remove the display.
  39. Unscrew ten 8mm screws from the grey inner casing with a Phillips screwdriver.
    • Unscrew ten 8mm screws from the grey inner casing with a Phillips screwdriver.
  40. Locate the sound card cable. Gently unplug the sound cable. Gently unplug the sound cable.
    • Locate the sound card cable.
    • Gently unplug the sound cable.
  41. Find the orange cable with the letters MB. Insert the spudger below the edge of the black tab and lift the black tab. DO NOT attempt to pull out the cable on this step.
    • Find the orange cable with the letters MB.
    • Insert the spudger below the edge of the black tab and lift the black tab.
    • DO NOT attempt to pull out the cable on this step.
  42. Locate the wire on the side of WWAN slot. Using the spudger, gently pull out the cable. Using the spudger, gently pull out the cable.
    • Locate the wire on the side of WWAN slot.
    • Using the spudger, gently pull out the cable.
  43. Gently flip the laptop with its bottom facing you. Remove four 8mm screws with a Phillips screwdriver.
    • Gently flip the laptop with its bottom facing you.
    • Remove four 8mm screws with a Phillips screwdriver.
    • Remove two 16mm battery casing screws with a Phillips screwdriver.
    • Remove two 16mm corner screws with a Phillips screwdriver.
    • Remove two 4mm screws inside battery housing with a Phillips screwdriver.
    • Removing the RAM is optional. Follow a separate guide to remove RAM if you feel the need.
  44. Holding the opening from the optical drive in one hand and the other hand on the opposite side of the laptop, lift and remove the back cover assembly. Holding the opening from the optical drive in one hand and the other hand on the opposite side of the laptop, lift and remove the back cover assembly.
    • Holding the opening from the optical drive in one hand and the other hand on the opposite side of the laptop, lift and remove the back cover assembly.
  45. Unscrew seven 4mm screws with a Phillips screwdriver.
    • Unscrew seven 4mm screws with a Phillips screwdriver.
  46. Unscrew one 6mm screw from the DC cable assembly with a Phillips screwdriver. Lift the DC cable assembly out of the casing. Gently unplug the DC cable.
    • Unscrew one 6mm screw from the DC cable assembly with a Phillips screwdriver.
    • Lift the DC cable assembly out of the casing.
    • Gently unplug the DC cable.
  47. Lift and remove the WI-FI Circuit board.
    • Lift and remove the WI-FI Circuit board.
  48. Use a spudger to pry the fan power cable. Lift and remove the fan. Lift and remove the fan.
    • Use a spudger to pry the fan power cable.
    • Lift and remove the fan.
  49. Lift and remove the USB circuit board out of its housing. Remove the orange cable from the mother board by gently pulling Remove the orange cable from the mother board by gently pulling
    • Lift and remove the USB circuit board out of its housing.
    • Remove the orange cable from the mother board by gently pulling
  50. Loosen the six flat head screws with a Phillips screwdriver. The flat head screws are attached to the heat sink piece.  Do not attempt to remove
    • Loosen the six flat head screws with a Phillips screwdriver.
    • The flat head screws are attached to the heat sink piece. Do not attempt to remove
  51. Gently lift and the motherboard. DO NOT TOUCH the coolant in the red squares DO NOT TOUCH the coolant in the red squares
    • Gently lift and the motherboard.
    • DO NOT TOUCH the coolant in the red squares
Conclusión
5 personas más completaron esta guía.
Eddie
Miembro Desde 17/09/15
331 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team 2-6, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Miembros
8 Guías creadas
it really helped me out with my extremely fast overheating pc. and now it is mutch cooler and working great, Thanks!
Bjorn stevens - Contestar
I wouldn’t rate this as extremely difficult though to be honest. I’d say moderate at best.
Clems - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 18
Últimos 30 Días: 74
Todo El Tiempo: 2,999
