Saltar al contenido principal
Dell XPS 17 L702X Keyboard Replacement
Qué necesitas
  1. Dell XPS 17 L702X Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Keyboard Replacement: paso 2, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Keyboard Replacement: paso 3, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 3, imagen 2 de 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Keyboard Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Keyboard Replacement: paso 5, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 5, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 5, imagen 3 de 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Keyboard Replacement: paso 6, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Keyboard Replacement: paso 7, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 7, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 7, imagen 3 de 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Keyboard Replacement: paso 8, imagen 1 de 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Keyboard Replacement: paso 9, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 9, imagen 2 de 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Keyboard Replacement: paso 10, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 10, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 10, imagen 3 de 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Keyboard Replacement: paso 11, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 11, imagen 2 de 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Keyboard Replacement: paso 12, imagen 1 de 1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Keyboard Replacement, Palm Rest: paso 13, imagen 1 de 1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Keyboard Replacement: paso 14, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 14, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 14, imagen 3 de 3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Keyboard Replacement: paso 15, imagen 1 de 1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Keyboard Replacement: paso 16, imagen 1 de 1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Keyboard Replacement: paso 17, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 17, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 17, imagen 3 de 3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Keyboard Replacement: paso 18, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 18, imagen 2 de 2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Keyboard Replacement: paso 19, imagen 1 de 2 Dell XPS 17 L702X Keyboard Replacement: paso 19, imagen 2 de 2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Keyboard Replacement: paso 20, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 20, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 20, imagen 3 de 3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Keyboard Replacement: paso 21, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 21, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 21, imagen 3 de 3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Keyboard Replacement: paso 22, imagen 1 de 1
    • Remove the palm rest from the laptop.
  23. Dell XPS 17 L702X Keyboard Replacement, Keyboard: paso 23, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement, Keyboard: paso 23, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement, Keyboard: paso 23, imagen 3 de 3
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Dell XPS 17 L702X Keyboard Replacement: paso 24, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 24, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 24, imagen 3 de 3
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Dell XPS 17 L702X Keyboard Replacement: paso 25, imagen 1 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 25, imagen 2 de 3 Dell XPS 17 L702X Keyboard Replacement: paso 25, imagen 3 de 3
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Dell XPS 17 L702X Keyboard Replacement: paso 26, imagen 1 de 1
    • Remove the keyboard from the laptop.
Conclusión
3 personas más completaron esta guía.
Monica Oropeza
Miembro Desde 09/17/15
381 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team 2-6, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
Miembros de 4
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 3,022
