Saltar al contenido principal
Dell XPS 15 Motherboard Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Dell XPS 15 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Dell XPS 15 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 15 Motherboard Replacement: paso 2, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 15 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 15 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 15 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. Dell XPS 15 Motherboard Replacement, Battery Disconnection: paso 6, imagen 1 de 2 Dell XPS 15 Motherboard Replacement, Battery Disconnection: paso 6, imagen 2 de 2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 15 Motherboard Replacement, Fan: paso 7, imagen 1 de 3 Dell XPS 15 Motherboard Replacement, Fan: paso 7, imagen 2 de 3 Dell XPS 15 Motherboard Replacement, Fan: paso 7, imagen 3 de 3
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 15 Motherboard Replacement: paso 8, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 15 Motherboard Replacement: paso 9, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 15 Motherboard Replacement: paso 10, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 10, imagen 2 de 2
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Dell XPS 15 Motherboard Replacement, Battery: paso 11, imagen 1 de 2 Dell XPS 15 Motherboard Replacement, Battery: paso 11, imagen 2 de 2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Dell XPS 15 Motherboard Replacement: paso 12, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 12, imagen 2 de 2
    • Do not pull up.
  13. Dell XPS 15 Motherboard Replacement: paso 13, imagen 1 de 1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Dell XPS 15 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the battery.
  15. Dell XPS 15 Motherboard Replacement, Motherboard: paso 15, imagen 1 de 2 Dell XPS 15 Motherboard Replacement, Motherboard: paso 15, imagen 2 de 2
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Dell XPS 15 Motherboard Replacement: paso 16, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 16, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 16, imagen 3 de 3
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Dell XPS 15 Motherboard Replacement: paso 17, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 17, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 17, imagen 3 de 3
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Dell XPS 15 Motherboard Replacement: paso 18, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 18, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 18, imagen 3 de 3
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Dell XPS 15 Motherboard Replacement: paso 19, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 19, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 19, imagen 3 de 3
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Dell XPS 15 Motherboard Replacement: paso 20, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 20, imagen 2 de 2
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Dell XPS 15 Motherboard Replacement: paso 21, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 21, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 21, imagen 3 de 3
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Dell XPS 15 Motherboard Replacement: paso 22, imagen 1 de 2 Dell XPS 15 Motherboard Replacement: paso 22, imagen 2 de 2
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Dell XPS 15 Motherboard Replacement: paso 23, imagen 1 de 3 Dell XPS 15 Motherboard Replacement: paso 23, imagen 2 de 3 Dell XPS 15 Motherboard Replacement: paso 23, imagen 3 de 3
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Dell XPS 15 Motherboard Replacement: paso 24, imagen 1 de 1
    • Use your hands to lift up the motherboard.
Conclusión
12 personas más completaron esta guía.
Evan Shui
Miembro Desde 04/26/17
320 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S21-G6, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Miembros
30 Guías creadas
2 comentarios
where is camera cable
phong thanh - Contestar
Wow man that is awesome job. Where can you get a newer motheboard for the same laptop?
R E - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 33
Ultimos 30 días: 173
Todo El Tiempo: 23,746
