Saltar al contenido principal
Dell XPS 15 L521X Hard Drive Replacement
Qué necesitas
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: paso 1, imagen 1 de 1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: paso 2, imagen 1 de 1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: paso 4, imagen 1 de 1
    • Gently unplug and remove the hard drive
Conclusión
2 personas más completaron esta guía.
SHELDON SANTOS
Miembro Desde 03/19/18
614 Reputación
6 Guías creadas
Equipo
Un comentario
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,206
